  • Enable multicast on the boundary nodes.
  • Configure Multiprotocol Label Switching Virtual Private Network (MVPN) on the boundary nodes, for layer 3 VSN.
  • Configure the same policies as the boundary node on the peer boundary nodes.
Perform this procedure to configure IS-IS Multi-area SPB IPv4 routed multicast redistribution on a specific Virtual Router Forwarding (VRF) instance on the switch.
  1. Enter VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    router vrf WORD<1-16>
  2. Create the IS-IS Multi-area SPB IPv4 routed multicast redistribution instance on the VRF:
    isis multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home]
    If you do not specify the direction for redistribution then the system applies the redistribution in both directions by default.
  3. Optional: Configure a route policy to govern the redistribution:
    isis multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home] route-map WORD<1-64>
  4. Enable the Multi-area SPB IPv4 routed multicast redistribution instance on the VRF:
    isis multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home] enable
  5. Verify the Multi-area SPB IPv4 routed multicast redistribution configuration on the VRF:
    show isis multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home] [vrf WORD<1-16> | vrfids WORD<0-512>]
  6. Exit to Global Configuration mode:
    exit
  7. Apply the Multi-area SPB IPv4 routed multicast redistribution on the VRF:
    isis multi-area ip apply redistribute routed-multicast [home-to-remote | [remote-to-home] vrf WORD<1-16>
Configuring IS-IS Multi-area SPB IPv4 routed multicast redistribution for home to remote direction on VRF VRF1:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf VRF1
Switch:1(router-vrf)#isis multi-area ip redistribute routed-multicast home-to-remote
route-map test
enable
Switch:1(router-vrf)#show isis multi-area ip redistribute routed-multicast home-to-remote
vrf VRF1
         ISIS Multiarea Redistribute List for routed multicast - VRF VRF1
DIRECTION            ENABLE     RPOLICY
home-to-remote       TRUE       test
Switch:1(router-vrf)#exit
Switch:1(config)#isis multi-area ip apply redistribute routed-multicast home-to-remote
vrf VRF1
The following table defines parameters for the isis multi-area ip redistribute routed-multicast and the isis multi-area ip apply redistribute routed-multicast commands.
Variable Value
enable
Enables IPv4 routed multicast redistribution on the VRF instance.
home-to-remote
Specifies the IPv4 routed multicast redistribution configuration for home to remote direction.
remote-to-home
Specifies the IPv4 routed multicast redistribution configuration for remote to home direction.
Specifies the name of the route policy.
vrf WORD<1-16>
Specifies the multicast routing redistribution configuration for specific VRF instance.
